SIM900 Customer Flash Loader
I turned it on, i sent some at commands:
+CPIN: NOT INSERTED
+CFUN: 1
AT
OK
AT+GMR
Revision:1137B08SIM900A32_ST
OK
but after it sim900 turned off and I can not turn it on! I heard that this happened for some guys! and they could not turn it on!
anyone know why? how can I use it again?
PS: the power supply is 12V 2A, using LM7805 and 1N4007 to make 4.2V...
Use LM2576-ADJ... Check out its details at element14.com
A very bad decision !!!
See as example synchronous step-down regulator
https://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00169322.pdf
NO USE LDO !!!!
I own an evaluation board, and it uses MIC29302 to get the 4.2v for the SIM900, it works perfectly!
why dont use LDO if the supplier does?
Also, LDO are considerer better that any DC-DC converter when trying to avoid any noise, since DC-DC could deliver some high frecuency noise that in case of SIM900 could be critical
In other issues, still lookng for 1137B04SIM900B64_SAMSUNG or later firmwares,anyone?
I was planning to joke about the fact i replied myself, but i'm a grown up...
Anyway, just sharing...
  • 1137B07SIM900B64_SAMSUNG.rar
I need to use SIM900 to decode DTMF. Any one know how to do, please tell me. I have try many firmware version (B06,B08,B10,B11) only receive "ERROR" when I type AT+DDET=1
u should upgrade your firmware to version 1137B08SIM900M64_ST_DTMF_JD_MMS i would attach that here in the post ,
Actually i also faced the same problem after upgrading the firmware it was OK,
  • 1137B08SIM900M64_ST_DTMF_JD_MMS.zip
thank you very much, sherazi. I've done it
Is there a similar version for SIM900D?
Is there a version for SIM900D with jamming detection enabled?
Thanks.
well i have this file but i dont know if it has jamming detection
I have also attached the application for appgrading sim900 series modules
  • 1137B09SIM900D64_ST.zip
  • Simcom - sim900 Customer flash loader V1.01.zip
hello Sherazi can you uplaod latest firmware for SIM908 module. My current SIM908 firmware is Revision:1137B03SIM908M64_ST
Thanks in advance.
Sim900 can be drives easily! so, can we drive Sim908 as easy as sim900?
Hello Chipseller can u please get me latest firware for SIM908/SIM908-C modules. MY current Firmware is SIMCOM_SIM908 Revision:1137B03SIM908M64_ST. Thanks In advance.
Hello everyone I just got latest firmware for SIM900 , it B11 version , sharing it , hope will help u.
  • 1137B11SIM900M64_ST.rar
Reactions: sherazi
    sherazi
hi,
how can i get username & password of ftp://simcom.exavault.com
any idea?
try these .. if any one have username password plz share!
username :myd
password : myd
---------- Post added at 11:51 ---------- Previous post was at 11:48 ----------
Hi techie
The Sim FTP site is up again now, so here are two documents which may help you transfer to the sim900
whats the site??
my current version of Sim908 is 1137B03SIM908M64_ST
anyone has latest version of sim908?
Does anyone have firmware for SIM900 which can decode DTMF and have whiteList function?
I have found only one firmware for DTMF decode (1137B08SIM900M64_ST_DTMF_JD_MMS), but it has not got whiteList function. Does any one have firmware that have DTMF and whiteList function, please share me. Thanks
I just want to make sure I am getting this straight. I have an EVB and SIM900 modems. The Firmware that is pre-loaded is Revision:1137B11SIM900M64_ST.....Am I understanding correctly, that in order to access the MMS AT commands....I have to change the firmware? It currently spits out errors when I try to use any of the MMS commands.
Thanks in advance,
Amie
