Bearer parameters are not user deifned.. you can just read the status of it under different operation of GPRS connection and under GPRS sending or getting data and disconnecting.....
1) For vodafone and airtel sim card, what should i send for above commands ?
2) what does it indicates for commands type value 3 and cid value 1 as per above command?
Greetings,
I need to access websites using url without ip address, is it enough to configure dns setting and send at+cipstart to do it. and i also need to get the ip address of the url can i use this AT+CIPSRIP. pls help me.
THANKS,
