Jan 1, 2018 #1 A akshaybhavsar Full Member level 2 Joined May 5, 2016 Messages 135 Helped 2 Reputation 4 Reaction score 2 Trophy points 18 Activity points 898 Hello, I am using SIM808 module in my application.I have to send packets to server every 1 sec.data will have upto 150 bytes including.Below is my command flow. AT+CGREG=1 AT+CREG=1 AT+CSQ AT+CADC //READ ADC AT+CIPSTART=TCP,"ip ADDRESS","PORTNO" AT+CIPSEND=1 SEND DATA I have to repeat atleast these AT command after every 1 sec.Is it possible to set that much low frequency(1 sec)? My existing system takes 6 sec
Jan 1, 2018 #2 Z zia Full Member level 5 Joined Sep 24, 2010 Messages 284 Helped 27 Reputation 54 Reaction score 26 Trophy points 1,318 Location Islamabad Pakistan Activity points 2,746 hi akshay , it seems you using using tcp connection , kindly check sim808 transparent mode, and don't close tcp socket
Jan 1, 2018 #3 A akshaybhavsar Full Member level 2 Joined May 5, 2016 Messages 135 Helped 2 Reputation 4 Reaction score 2 Trophy points 18 Activity points 898 If i choose transparent mode.It will no longer receive AT commands Regards, Akshay
Jan 2, 2018 #4 A akshaybhavsar Full Member level 2 Joined May 5, 2016 Messages 135 Helped 2 Reputation 4 Reaction score 2 Trophy points 18 Activity points 898 How do i resolve this?
