signal square with pic 16F877A
razsab
Newbie level 5
hi for all , after I wan't generate signal square with pic 16F877A
with 2 Mhz frequency
i want the diagram cabling with isis and the code with the mikroc
You can use the compare or PWM section of the CCP module.
You mentioned a frequency of 2MHz? Is this the required output frequency or the frequency at which the PIC runs.
For operation with CCP module (with code), check here: https://www.edaboard.com/blog/1820/
Hope this helps.
Tahmid.
