Signal power in Matlab
elmarconi
Newbie level 3
Newbie level 3
hi all
I'm using the functions(fft,ifft) in a matlab code,theoretically signal power must not be changed before and after transformation according to Parsaval theorem.
But when calculating the signal power before and after using E{X^2},the power of the 2 signals aren't the same.
please can any body helping solving this issue.
Thanks
Does your code filter your fft results?
No, without using any filter, just ifft only.
and compare between the signal power before and after the ifft
Result of fft and ifft are complex numbers even though inputs may not be. Are you taking care of that?
it doesn't affect the signal power
E{X^2}, X is absolute.
so it doesn't affect the power if the signal is complex or real
I didn't say it affects the signal power, just wanted to make sure if you've taken it into consideration or not while calculating the power. If you're sure it's right then I can't offer anything else to check other than debuging a very simple case with just 'fft', 'ifft' and power calculation functions.
