'signal connected to multiple drivers' problem
serhannn
Member level 4
Member level 4
Hi. We are trying to code a sort of accumulator in Verilog, but when we write the code below, we get an error saying that "this signal is connected to multiple drivers" for every signal that even does not appear in the expression below. For example, we also have a register "N" and we get the same error for it, too.
sum_temp=(a + k*dx - dx_half)*(a + k*dx - dx_half)+m*(a + k*dx - dx_half)+nn;
sum=sum+sum_temp;
Does anybody know the reason for this error? Thanks a lot for your help.
perhaps you have "if N = 5" instead of "if N == 5" someplace.
u can use swith,ff... to avoid multiple drivers' problem
Usually this happens when the signal N is assigned values in different processes
like in VHDL (I'm not very familiar with Verilog)
process1:process(clk)
begin
   if rising_edge(clk) then
      N <= some_value;
end process;
process2: process (clk, ...)
begin
      N <= some_other_value;
end process;
