zizi110
Member level 1
Hi all,
i am trying to design a sigma delta modulator in pspice by ABM library , here it is my schematic , nut it dont work!
first block subtract the input from output , then the result goes to integrator and then if the result is positive the output becomes 5 , else the output becomes zero and this output goes to 74175 that its clock rate is 10kHz ..... however this circuit does not work!
any suggestion appreciated.
