Sigma Delta ADC -SNR & SNDR calculation
kapil411
Newbie level 5
hiiiiiiii
I'm working on sigma Delta ADC
CAN ANY1 PLEASE HELP ME ON WORKING WITH CADENCE SPECTRE FOR snr CALCULATION
HOW MANY CYCLES I SHOULD RUN THE TRANSIENT ANALYSIS??
IN ORDER TO CALCULATE snr
PLEASE HELP ME IN FIGURING OUT THESE VALUES...
how to come to conclusion to FFT fundamental frequency of input signal ,
NO. of samples, should give you enough noise samples to measure SNR.
________________________________________________________
i'm goin for OSR -64
12800HZ=CLK FREQUENCY
then input freq shud be 50hz
but i'm confused by seeing some other calcualtions based on FFT SNR from other posts ...
how to come 2 conclusion abt...
No_Of sample?????
No.of FFT points..????
how long to run transient analysis???
which points to be strobbed in transient analysis???
please do help..i'm confused
with regards ,
mnk...
To calculate SNR more calculations than a simple FFT are required. So, it is easier to import the results into matlab, then calculate the SNR.
In order to transfer results to Matlab, one can write a Verilog-A module to capture the output of the modulator in right time based on modulator clock and then write the data in a file. Matlab can simply import the text files and convert to array. For SNR/SNDR calculation in Matlab, you can use delta sigma toolbox or write your own codes. Anyway, it should include following steps.
1- window the data by blackman, or hann, etc.
2- extract signal power from the data.
2-1- to do so, both sin and cosin vectors of the signal frequency should be multiplied to data, and then sum the total energy at DC.
3- calculate noise+distortion (N+D) power as: total power - signal power
4- SNDR= signal power / N+D power
May help,
Ali
This is my first participation to this forum. Happy to be with you.
I found in some researchs formulae to calculate SNR, you find attached to this message two of them
Now the question is: If the NTF function is complicated, how to calculate its integral?
Good luck
  • 731989.pdf
  • 02.6_5.pdf
My comments were about transient simulations. If you need to find SNR through equations, you may replace Z (or S) with exp[jw] (or jw), where w=2*pi*f. Then sweep the f along with the bandwidth and calculate the signal and noise power.
Ali
