May 17, 2010 #1 C cnurettin Newbie level 4 Joined Jan 15, 2008 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,314 Hi all, I need to see pin number in board ( in Pcb desing ). For example , I can't see pin number for 128 pin IC . Maybe this is not important for which IC has 4-8-16 pins. But more pins are problem... Is there anybody knows how can i show pin numbers in board? Best Regards, Cihat Nurettin YILMAZ
May 17, 2010 #2 keith1200rs Super Moderator Staff member Joined Oct 9, 2009 Messages 10,865 Helped 2,065 Reputation 4,130 Reaction score 1,596 Trophy points 1,403 Location Yorkshire, UK Activity points 57,270 Go to "options" then "set" then "misc" - there should be a check box for "display pad names". Keith.
May 17, 2010 #3 PCBWING Banned Joined May 17, 2010 Messages 91 Helped 16 Reputation 32 Reaction score 5 Trophy points 1,288 Location Internet Activity points 0 If when the image to enlarge, can automatically display number, so that it easy for the designer.
May 17, 2010 #4 C cnurettin Newbie level 4 Joined Jan 15, 2008 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,314 Thank you Keith. I showed pin number . Best regards,
May 17, 2010 #5 keith1200rs Super Moderator Staff member Joined Oct 9, 2009 Messages 10,865 Helped 2,065 Reputation 4,130 Reaction score 1,596 Trophy points 1,403 Location Yorkshire, UK Activity points 57,270 PCBWING said: If when the image to enlarge, can automatically display number, so that it easy for the designer. Click to expand... Only if you have set the option in the menu first. Keith.
May 17, 2010 #6 PCBWING Banned Joined May 17, 2010 Messages 91 Helped 16 Reputation 32 Reaction score 5 Trophy points 1,288 Location Internet Activity points 0 keith1200rs said: PCBWING said: If when the image to enlarge, can automatically display number, so that it easy for the designer. Click to expand... Only if you have set the option in the menu first. Keith. Click to expand... Thank you! That is considerate
