should any current limiting resistors be used when connectin
Always_Confused_Sudent
Junior Member level 3
do i have to use a resistor when i connect an IO pin of a PICmicro to an IO pin of another PICmicro?
Re: should any current limiting resistors be used when conne
no need if they are working on the same clock for IO lines.
for port lines you do not need it even if they have there own clock.
but you may need a pullup resisrot in both the cases.
hock
It depends on your configuration, most of the time you need pull up resistors.
if one of them input and other output(permanently) you don't need any resistor...
Hai
In PIC if an I/O pin configured as output gets shorted to the VCC or GND , You lost that I/O for ever. If that I/O is input, nothing happens.Use limiting resistors with this in mind wherever applicable!
Picstudent
These devices are designed in such a way that you don't need to use any resistors if connecting them pin(s)-to-pin(s).
Even if there is a confict on two pins (both set as outputs, one L one H) the L-one can sink some mA but the H-one have only week pull-up component(s) inside so the final stage of this combination will be L and this will not damage the other output...
