Shift Registers as example of illustrating Hold Violation
paulki
Full Member level 2
Bangalore
Hi Designers,
Anybody can you please illustrate the Shift registers example for the Hold violation and how to fix it in the timing.
It would be more helpful to understand.
-paulki
Every Flip-flop has setup/hold window around active clock edge. Setup before edge, hold after.
In shift registers data pass from Q-out of previous flop to D-in of the next flop directly, so it have minimal possible delay.
Data can pass to D-in inside hold window. To fix this violation you should put delay buffer from Q-out to D-in.
Another factor is clock skew. Clock to the next flop can arrive later than previous, co you need to put additional delay between Q and D.
Another way to fix hold violation is "useful skew" - delay clock to the previous flop relative to next flop.
