SFDR becomes worse with higher sampling frequency
kickbeer
Full Member level 3
i'm simulating a 8-bit Folding and Interpolating ADC and just found out that its SFDR is at 60dB at sampling rate of 25MHz. When i increase the sampling rate to 40MHz the SFDR of my ADC degrades to 30dB. Does anyone have the idea which main factors cause this? Thanks in advanced
dick_freebird
Advanced Member level 5
USA
I would imagine it relates to the settling time inside
the pipeline(?) stages, finite time to get to sub-LSB
error against a shortening period.
Have you determined which element of the SFDR rollup
is driving the degradation (noise vs offset vs gain error
or whatever)?
I am somewhat surprised at getting 60dB SFDR (1000:1)
out of an 8-bit (256:1) machine. That is suspicious to
my barely-DAQ-educated eye. Perhaps this initial result
is unrealistically good and realism rolls on harder at 40MHz
simulated.
    kickbeer
kickbeer
Full Member level 3
or whatever)?
I haven't determined yet. What do you mean by SFDR rollup?
dick_freebird
USA
I mean that SFDR is a combined figure of merit that
embodies both DC (INL, DNL, etc.) and frequency
dependent (bandwidth, settling time) effects. As such
it is perhaps a good quick-comparison metric, but
not necessarily enlightening about the dominant
effects. By decomposing (or resimulating with the
different aspects picked off individually) you might
see what drives the degradation more clearly.
    kickbeer
