first let me clear your question..there is no 6 SSD . SSD is seven segment display. you can built A circuit with 5 volt supply and if u know binary code in the scene that is more than enough to write the code. you need 470ohm of pull up array to connect to the seven segment.use 8051 any port i think below image helps you
