settling time and propogation time delay simulation
Junus2012
Advanced Member level 5
Italy
Dear friends
I an simulating the total settling time of t he operational amplifier. I am connecting it as a buffer and I apply an input pulse. I have no problem to measure the slew rate, but when I tell the calcultaor to calcultae the settling time it take several periods of my signal, why ??
I also would ask you in case if I want to measure the linear settling time under the small signal condition, how much should I apply step voltage so that that the op-amp is not slewing ? also how to measure the propogation time delay ??
thank you in advance
Hi Senan=Junus ;-)
for the large signal mode, perhaps **broken link removed** may be helpful.
Scroll down to FO4 Inverter Delay Simulation
erikl
Dear friends
Of course, I don`t know which calculator you are using and if it is able at all to calculate the settling time. But you are right that sometimes the settling time is overshadowed by the slew rate.
The settling time is a parameter that involves no non-linear effect and, thus, the input signal must be small enough not to cause slewing - that means not to saturate the first stage of the opamp.
I think, in simulation it is not a problem to use input levels of - let`s say - 0.1mV or so.
As an outcome of some similar investigations I have some simulation results at hand for the opamp type AD845 which may be interesting for you:
* Input step 1mV: Output ringing with settling time (1%) approx. 0.8µs (gain of 2) and 0.3µs (gain of 5),
* Input step 1V: Output rise time (slew rate effect) for a gain of 10: 0.9µs.
nice to remember my old name Erikl :)
Hello All
in the first part of my problem I was simulating the total settling time which consist of (Propagation delay+ S.R + linear settling) but as I mentioned the calculator was taking some periods, perhaps it just come to my mind , i must apply only a zero to one or one to zero rather than applying a periodic input pulse signal then the calculator will be confused.
for the only linear settling time simulating I did as you suggested me to apply like 0.1 V, but isnt this time has also a part of the linear response time (propagation time delay )??? how to separate each other??
third, I also asked this question before and perhaps you answered me
why we consider the unity gain buffer is the worst case settling time and S.R measurement ? I know this represent the largest feedback and it is the worst case stability but hoe that effect the transient behavioural. I read from Jouhn Marting book that the linear settling time is inverse proportional to the closed loop bandwidth, which mean the unity gain buffer has the fastest linear settling time not the worse. in addition that I read in one paper that there is no difference to measure S.R with open or closed loop because it depend on the charging discharging current
I am sorry for my long post but I dont know how to make shortcut :)
thank you again
Hello Junus (I guess this is your Italian name, Senan was your German name, isn't it? ;-) ),
I'll try and explain this apparent contradiction:
This is only true if the phase margin can be kept above 60° within the whole bandwidth, and for all considered closed loop gains. It guarantees few overshoot and no ringing. As you probably know, this is as more difficult as lower the closed loop gain, and, by this, as higher the bandwidth is.
… why we consider the unity gain buffer is the worst case settling time and S.R measurement ? I know this represent the largest feedback and it is the worst case stability but hoe that effect the transient behavioural.
This is valid for phase margins < 60° , where large overshoot and ringing will occur, s. the foll. comparison from Razavi's book:
Considering an opAmp, whose phase margin falls below the 60° limit at low closed loop gains - as smaller the closed loop gain, as lower its phase margin will be, and as heavier overshoot and ringing it will create. By this, it takes longer for the output signal to stay in the required tolerance interval - hence the unity gain mode will create the longest settling time, s. the figure from the foll. page:
thank you again
Are you sure that the mentioned book refers to the settling time ? I think, the rise time will be inverse prop. to the bandwidth.
Regarding the slew rate, the loop must NOT be open. The reason is as follows: For testing the SR the first stage only must be saturated without saturating the following stages - in particular the output stage.
This can be accomplished with heavy feedback only and the effect is the following:
The input step (e.g. 1 Volt) drives the first stage into saturation - until the feedback action "slowly" (that is the slew effect) brings the whole circuit back to the linear operation.
Here's a slide from a lecture* by D.A. Johns & K. Martin where they actually claim this for settling time, but precisely for linear settling time, which, I think, complies with my above statement for phase margins ≧ 60° (no ringing):
linear_settling_time.png * "Advanced Current Mirrors and Opamps", University of Toronto, 1997
View attachment 83948 * "Advanced Current Mirrors and Opamps", University of Toronto, 1997
Hi Erik,
reference is made to your statements in post#5:
...if the phase margin can be kept above 60° ............. It guarantees few overshoot and no ringing.
I think, in case there is no overshoot and no ringing there is not much difference between settling and rise time.
More than that, I must confess that - up to now - I didn`t hear about the term "linear" settling time.
To my understanding, the term "settling time" always applies to linear systems only. But I may be in error because it´s "only" a matter of definition.
Hi Lutz,
Yes, I think the same.
... up to now - I didn`t hear about the term "linear" settling time.
Same for me. If I interpret their above slide correctly, I'd think the wording "linear" in Johns/Martin's term "linear settling time" refers to an output response without ringing - but this is just guesswork.
erikl
Hello guys
thanx a lot for your active participation
the linear settling time is the final part of the settling time when the op-amp leave the large signal condition after the slew rate as you can see in t he attached file, John Marting and Holberg also differentiated between the linear and non linear settling time.
later I will attache you the page Nr from the both references with the examples from John Martin
Hello guys
As I understand from you
the rule of the larger closed loop bandwidth will lead to better settling time if only the phase margin is greater than or equal to 60
any way as I said before, i will show you the examples from John Martin, when he solved to find the settling time from the closed loop bandwidth, he didnt consider the phase margin.
in sense ,I agree with you both because the phase margin has an effect on the time behavioural as from the pics of Behzad applied by Erikl
  • 466359863287538299597392756AN359.pdf
Hi Junus,
so it seems you have found the answer by yourself.
Thanks for the AD application note. I did not know about it - up to now.
I must thank you all you guys,
again I forgot to appload the John Examples :) but I would dó it latrer :)
Regards
Hi Junus,
hello
I attached you a parts from John Martin regarding the linear settling time
the attachments are in sequence
have fun :) and thank you
