[SOLVED] setting system clock for msp 430 f 4784
sammey_geek
Junior Member level 1
india
hi..
i am a newbie to embedded system....i pretty confused on how to write a code to set a system clock frequency for msp 430 f4784...here is my question..
A clock source of 32Khz is attached to the clock inputs of an MSP430F4784 controller, Set up the controller MCLK to 4Mhz and output the MCLK clock on MCLK pin of the controller...
This is the code provided with code composer studio
// MSP430x47xx Demo - FLL+, Output 32kHz Xtal + HF Xtal + Internal DCO
// Description: This program demonstrates using an external 32kHz crystal to
// supply ACLK, and using a high speed crystal or resonator to supply SMCLK.
// MLCK for the CPU is supplied by the internal DCO. The 32kHz crystal
// connects between pins Xin and Xout. The high frequency crystal or
// resonator connects between pins XT2IN and XT2OUT. The DCO clock is
// generated internally and calibrated from the 32kHz crystal. ACLK is
// brought out on pin P1.5, SMCLK is brought out on P1.4, and MCLK is
// brought out on pin P1.1.
// ACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO = 32 x ACLK = 1048576Hz
// //* An external watch crystal between XIN & XOUT is required for ACLK *//
// NOTE: External matching capacitors must be added for the high
// speed crystal or resonator as required.
// MSP430x47xx
// /|\ | XIN|-
// | | | 32kHz
// ---|RST XOUT|-
// | XT2IN|-
// | | HF XTAL or Resonator (add capacitors)
// | XT2OUT|-
// | P1.5|--> ACLK = 32kHz Crystal Out
// | P1.4|--> SMCLK = High Freq Xtal or Resonator Out
// | P1.1|--> MCLK = Default DCO Frequency
// P. Thanigai / K.Venkat
// Texas Instruments Inc.
// November 2007
// Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.42A
#include <msp430x47x4.h>
void main(void)
volatile unsigned int i;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
FLL_CTL0 |= XCAP18PF; // Set load capacitance
FLL_CTL1 &= ~XT2OFF; // Turn on XT2
// Loop until 32kHz crystal stabilizes
do
IFG1 &= ~OFIFG; // Clear oscillator fault flag
for (i = 50000; i; i--); // Delay
while (IFG1 & OFIFG); // Test osc fault flag
FLL_CTL1 = SELS; // Select SMCLK source as XT2CLK
FLL_CTL2 |= XT2S_2;
P1DIR = BIT1+BIT4+BIT5; // Set P1.1,4,5 as outputs
P1SEL = BIT1+BIT4+BIT5; // Select P1.1,4,5 as clocks
while(1); // Loop in place
