Jun 13, 2019 #1 D Darkcrusher Member level 5 Joined Dec 30, 2010 Messages 87 Helped 21 Reputation 42 Reaction score 20 Trophy points 1,288 Location Belgium Activity points 1,786 Hi, My application currently uses 2XAA batteries in series to have 3 Volt output and 3600mAH total capacity I need to double the current capacity. Is it allowed to put 2XAA in parallel with again 2xAA in parallel ? Looking forward to replies! If more info needed let me know .
Jun 13, 2019 #2 crutschow Advanced Member level 6 Joined Feb 22, 2012 Messages 4,459 Helped 998 Reputation 1,994 Reaction score 1,123 Trophy points 1,393 Location Colorado USA Zulu -7 Activity points 25,279 Yes, you can put them in series parallel. Do you have room for two C batteries, which have about 3 times the capacity of an AA?
Jun 13, 2019 #3 schmitt trigger Advanced Member level 5 Joined Apr 17, 2013 Messages 2,725 Helped 859 Reputation 1,722 Reaction score 850 Trophy points 1,393 Activity points 18,445 As long as they are identical batteries, and with the exact same amount of charge(*), I guess they can safely be paralleled. (*) This means always replace both batteries simultaneously with same brand, brand-new, fresh batteries. But I also second Crutschow's suggestion: utilize a larger battery.
Jun 14, 2019 #4 D Darkcrusher Member level 5 Joined Dec 30, 2010 Messages 87 Helped 21 Reputation 42 Reaction score 20 Trophy points 1,288 Location Belgium Activity points 1,786 Thanks schimtt trigger and crutschow!
