serial to parallel while maintaining a constant clock
player80
Full Member level 2
I'm trying to convert a serial to a parallel stream, the problem I have is maintaining the clock rate on the output.
The input is a clock, data, frame signal.
000 11111111 11111111 11111111 11111111 000 frame
111 01010101 01010101 01010101 01010101 111 clock
000 00000000 11111111 11111111 00000000 000 data
The output should be:
0101 CLK-OUT
0011 D0
0011 D1
0011 D2
0011 D3
1100 D4
1100 D5
1100 D6
1100 D7
1111 frame
at the beginning of the frame clk-out should not be a problem but how can I maintain a constant clock after the last 8 bits were shifted in? The input clock will stop once the frame has completed.
you need to have a system clock that is equal or faster than the IO clock. Or the input clock must be a gated version of a fixed rate clock and transitions must not be allowed to stop for long periods of time.
I don't know how you got the data bits, but I'll assume the input/output relationship makes sense and you can implement that part without issues. It is usually more helpful to have data listed as a,b,c,d,e,f ... as then it is clear if there is some permutation of bits.
