Serial comunication between 2 PIC12f675 (Pic Basic language)
lanpu
Newbie level 1
Hi, can somebody help me please!!!
I have 2 pic12f675 and this code for a serial cominication:
Recceiver
DEVICE pic12F675,intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, bod_off, protect_off
INCLUDE "modedefs.bas"
define OSCCAL_1K 1
ledr var gpio.1
leda var gpio.2
ledv var gpio.4
datos var byte
high ledr
pause 500
low ledr
recibir:
serin gpio.0,N2400,1,recibir,datos
if datos="A" then high ledr
pause 1000
if datos="B" then high leda
pause 1000
if datos="C" then high ledv
pause 1000
low ledr:low leda:low ledv
goto recibir
end
Emitter:
  DEVICE pic12F675, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, bod_off, protect_off
define OSC 4
define OSCCAL_1K 1
botonA var gpio.1
botonB var gpio.2
botonC var gpio.4
transmitir:
if botonA=0 then envio1
if botonB=0 then envio2
if botonC=0 then envio3
goto transmitir
envio1:
serout gpio.5,N2400,["A"]
pause 500
goto transmitir
envio2:
serout gpio.5,N2400,["B"]
pause 500
goto transmitir
envio3:
serout gpio.5,N2400,["C"]
pause 500
goto transmitir
end
i dont know what's wrong, somebody knows the way to do this comunication???
some example or something??
thanks!
yoramgr
Member level 2
Israel
If it's still relevant, I think you better try and move this question to the "Microcontrollers" forum. I'm not sure "PC Programming" is the right place.
lockman_akim
Advanced Member level 1
Malaysia
try this
receiver:
define OSCCAL_1K 1
ledr var gpio.1
leda var gpio.2
ledv var gpio.4
datos var byte
high ledr
pause 500
low ledr
recibir:
if datos=1 then high ledr
pause 1000
if datos=2 then high leda
pause 1000
if datos=3 then high ledv
pause 1000
goto recibir
end
transmitter:
define OSC 4
define OSCCAL_1K 1
botonA var gpio.1
botonB var gpio.2
botonC var gpio.4
dim data as byte
transmitir:
goto transmitir
envio1:
data = 1
serout gpio.5,N2400,[data]
pause 500
goto transmitir
envio2:
data = 2
pause 500
goto transmitir
envio3:
data = 3
pause 500
goto transmitir
end
Dr.Schwartz
Newbie level 1
Does this code work has anyone tried it? Im working on a similiar program
