Serial communication with proteus
dmta
Member level 2
Member level 2
Earth
Hi all,
I am trying to do serial communication using proteus and trying to write a value continously to the hyper terminal but I'm getting some wierd symbols. What am I doing wrong ? BTW BEGINNER
Regards
HTML:
void main(){
     unsigned int analog;
     TRISA.F0 = 1;
     Usart_Init(9600);
     while(1){
          delay_ms(500);
          analog = Adc_Read(0);
          Usart_Write(analog);
Usart_Write() functions writes ascii characters like '0'. You analog variable is an interger variable. Convert it to string using IntToStr() function and then use USART_Write_Text(stranalog); I think you are using mikroC PRO 8051. Right?
Hi and thank you for your reply !!!!!!!
I did the follwoing changes but still not getting what I want. BTW I am using mikroC for pic
void main(){
     char txt[10];
     TRISA.F0 = 1;
     Usart_Init(9600);
     while(1){
          delay_ms(500);
          IntToStr(analog, txt);
          Usart_Write(txt);
USART_Write() is to send individual Characters. Use UART_Write_Text(txt); If you are using UART1 then you should use UART1_Init(9600); and UART1_Write_Text(txt); Is there UART_Write(), UART_Write_Text(), and UART_Init() functions in mikroC PRO PIC? I think it is UARTx.
