Sensor-transceivers-pic 16f877a-gsm
aadebola5
please i need a guide on how to interface a pir sensor with a rf315MHz transmitter, and how to interface the rf315MHz receiver with the PIC16F877A, and how to interface the PIC with my gsm module (SM5100B-D)..i dont know if a PIC is needed with the transmitter to send the data to d receiver.. please i dont really know much on this am kind of new to these...and i have been reading some materialls on how to intterface and program this project but dey are not really helping..lease i need help from y guys...thanks
do one thing first start to study about that sensor,tx,rx,and microcontroller (hardwere,softwere)k then u ll get some knowledge then u tried to do your self (just imagine and do it k) then u ask others for help bcz i faced same problem...
please i need assistance on these codes am goin to paste now, the function of the code is to switch on the LED wirelessly if a motion us detected i used CCS to write the code but it is givin me errors..please i need help..thanks
the transmitting side
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
#include "C:\Users\Adebola\Documents\project\pic prog\motion_rf.h"
//all these # below set up the PIC
//#include <16F877A.h>
//#device adc=8
#FUSES NOWDT      //No Watch Dog Timer
#FUSES HS         //Highspeed Osc > 4mhz
#FUSES PUT        //Power Up Timer
#FUSES NOPROTECT  //Code not protected from reading
#FUSES NODEBUG    //No Debug mode for ICD
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOLVP      //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD      //No EE protection
#use delay(clock=20000000)              // Sets crystal oscillator at 20 megahertz
#use rs232(baud=4800, xmit=PIN_C6, rcv=PIN_C7) //Sets up serial port output pin & baud rate
#define PIR_SENSOR PIN_A0
#define TRS PIN_C6
#define sw PIN_A1
void uart_send(unsigned char data);
void main()
   BRGH = 0;
   SPBRG = 255;
   TX9 = 0;
   TXEN = 1;
   SYNC = 0;
   SPEN = 1;
  set_tris_a(0xff);
  set_tris_c(0x00);
   setup_adc_ports(AN0);
   setup_adc(ADC_CLOCK_INTERNAL);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   while(true)
   {  set_adc_channel(0);
      delay_us(20);
      if(PIR_SENSOR==0 && sw==0){
      output_high(PIN_C6);
      else{
         output_low(PIN_C6);
   while(TXIF==0);
         TXREG=data;
the receivers side
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
#include "C:\Users\Adebola\Documents\project\pic prog\motion_receiver.h"
//#device adc=8
#define RCV PIN_C7
#define RED_LED PIN_B7
void uart_rec(void);
void main()
   BRGH = 0;
   SPBRG = 255;
   SPEN = 1;
   RX9 = 0;
   CREN = 1;
   set_tris_c(0xff);
  set_tris_b(0x00);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_vref(FALSE);
    while(true)
      delay_us(20);
      if(RCV==0){
      output_high(PIN_B7);
      else{
         output_low(PIN_B7);
unsigned char uart_rec(void) {
         unsigned char rec_data;
         while (RCIF==0);
         rec_data = RCREG;
         return rec_data;
