ilamseeker
Hi guys,
I am doing a project in which i have to connect some sensors to a can bus. So, i need to have separate microcontrollers with each sensor which could read the sensor and put it on the can bus. Someone suggested me to use PIC microcontrollers for connecting each sensor to the CAN bus.
I am totally new to use PIC and need some help in selecting the right microcontroller. Can someone tell me where should i start? which development board should i buy for that?
If i have to make some circuit can someone share the schematic?
What i need to do is to make a few circuits with microcontrollers (or some ready made development boards with microcontrollers) and attach them with the sensors.
Any solution?
Thank you very much
Regards,
Iltaf Khalid
Any solution?
Thank you very much
Regards,
Iltaf Khalid
