[PIC] sending data to pic via max 232 by rs232 not working in proteus
damayantha1991
Newbie level 2
Newbie level 2
hi guys this is my 1st post in this forum !!
I need send data between pc and pic so i made this schematic using proteus wrote the very simple ccs c code for pic 18f2550
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
#include<18f2550.h>
#fuses NOWDT,HS,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,INVERT,parity=N,bits=8)
void main()
  char a;
  printf("Start typing ...\n.");
  while(1)
    a=getc();
    putc(a);
and my schematic is goto https://obrazki.elektroda.pl/2276196000_1388233204.jpg or
and when i run the code the result is like this https://obrazki.elektroda.pl/6774018100_1388233383.jpg
or goto
so friend before this i used exsisr.c with little change
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
#if defined(__PCM__)
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#elif defined(__PCH__)
#include <18F2550.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS,INVERT)
#elif defined(__PCD__)
#include <30F2010.h>
#fuses HS, NOWDT, NOPROTECT
#use rs232(baud=9600, UART1A)
#endif
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   t=next_in;
   next_in=(next_in+1) % BUFFER_SIZE;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
#define bkbhit (next_in!=next_out)
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   next_out=(next_out+1) % BUFFER_SIZE;
   return(c);
void main() {
   enable_interrupts(int_rda);
   #if defined(__PCD__)
   enable_interrupts(intr_global);
   #else
   enable_interrupts(global);
   #endif
   printf("\r\n\Running...\r\n");
               // The program will delay for 10 seconds and then display
               // any data that came in during the 10 second delay
   do {
      delay_ms(10000);
      printf("\r\nBuffered data => ");
      while(bkbhit)
        putc( bgetc() );
   } while (TRUE);
so proteus result for this is https://obrazki.elektroda.pl/5680434400_1388234039.jpg
or goto
SO in the both above cases i clicked on rx vir: terminal pressed keyboard buttons but they(the characters i presed) did not appear in output terminal
if i say clearly in first case (according to my little code) i pressed keys buttons but output is like in image ("start typing" then nothing..)
in second case the long code i keep pressing keys for 10s but output like the image i added ( bufferd data..bufferd data.. as in there)
And also i Used hyperterminal with virtual serial port software in second experiment but same results came as in image..
I'm using proteus 7.8
Think u clearly got my problem and show me how to fix this...
please help me guyssss!!
thankzz
Remove the max232 and directly connect the Com port to the pic. it will work
