Hi
In regular request/response between client and server, first a client initiates a request to server, then server responses.
Assume that the server always knows the IP address of its clients (note that clients have dynamic IP address). Is it possible to send data to them without request from clients? By "without request from clients" I mean server must be able to send data to clients whenever wants.
Thanks
What do you mean by "Within a network segment"?
Also I saw some say about "Persistent Connection". Is it possible to use "Persistent Connection" for this?
Even with "persistent connection" the client starts the communication as far as i know (but i´m not 100% sure, I´m no network expert)
After the client has started, and the connection is persistent, then the server has the ability to talk to the client. (Maybe this way Voip works).
Maybe you find a network expert that can better assist you there.
