emr
Hi all,
I have an analog signal which is in a range of -5V and +5V. I want to use MCP3204. In its datasheet, it is said that the analog input range of ADC is 0.25V ~ Vdd. I don't know if it is possible but I thought that if I can apply a gain of 0.4 to the signal and then offset that signal with 2.5V, ADC can read that signal. The signal range will be -2V ~ +2V. So the range for the ADC will be 0.5V ~ 4.5V (Because the offset voltage of 2.5 is added.)
Is there any way to do this practically?
Thanks in advance,
Best regards,
Thanks in advance,
Best regards,
