David_
Advanced Member level 2
Hello.
I'm sorry for the weird title for this post but it was the best I could do.
Anyway I have begun a new project for a LCR meter and the first part of it all is power supply, I need a symmetrical power supply(Both positive and negative voltages) derived from one of two possible options:
1, A single battery of +3,7V.
2, Two batteries connected to give ±3,7V.
In order to convey the requirements for the power supply let me just tell you about how the device is thought to look like in the end.
This LCR meter will consist of a microcontroller(µC), a couple of data converters, some amplifiers for the front end to buffer the excitation signal and amplify the resulting voltage/current signals. ADUM4160 will be used to isolate a USB bus that will connect the device to a PC running Matlab where I will plot Impedance vs frequency and other stuff. But there will also be a LCD display so it can be used without a PC, oh and while it is connected to a PC I want to charge the batterie(s) with the USB 5V rail.
Oh I almost forgot, I will also design for a DC-bias voltage but that will have to wait to later in the design, but I don't want to use those IC's that convert a positive voltage to a higher positive voltage and a negative voltage because they only enable ≈20mA and I will want to have more current than that.
The meter will use the IV measurement technique to acquire the complex voltage and the complex current and then calculate the phase difference as well as all other parameters wanted.
So that is what will need to be powered and ether I'll use a single 3,7V battery to be converted into ±5V or I'll use two batteries and then convert a +3,7V rail into a +5V rail and a -3,7V rail into a -5V rail.
converting +3,7V into +5V appears to require a Boost DC-DC converter but what about -3,7V? do Boost converters handle both positive and negative voltages? or is there any topology that can produce ±5V from a single 3,7V source?
Then there are the question of how to isolate the USB 5V rail, does anyone have any topology to recommend?
One important requirement, I want a frequency for the converters that does not(nor its harmonics) happen to fall on the same frequency of the excitation signal which I hope will be from 100Hz to 1MHz. But it don't know if it is at all possible for me to design converters running at >1MHz but maybe I'll should give it a go.
The other option is to tune the converters to some weird frequency such as 112kHz and then mark that and its harmonics in software so they are not ever used. But can you really tune converter frequency's with such accuracy to enable say 112kHz? or do I calculate components for 112kHz and then it will run a somewhere near that...
Here it is anyway, I appreciate all comments or suggestions.
Regards
David_
Regards
David_
