Koroth
- Joined
- Jan 8, 2006
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Kerala, INDIA
- Activity points
- 1,387
Actually this is related to a more complex project(like what i done in the Van eck phreaking project). Please help to solve my problems. I am going to present it in a nicer way. You may think this as weird. Please dont give a complete alternate suggestion. Yes this is weird.
Basically I am going to use my old CRT monitor as a CRT tube only. The rest of TV circuits are going to be added to it.(Like tuner, demodulation etc..). Ok now scenario clear .....
After the received signal from the antenna I will tune it amplify it and demodulate it to get the video data.
Now I have the monitor ON with power supplied to it. The Data input to the monitor(15 pin VGA cable) is lying there hungry for input.
Now I am going to give the demodulated data to vga cable of monitor. Yes... I have impedence matched it to get it in to the corresponding voltage level of monitor. Then I fed it to the Blue input of VGA cable. Red and Green are left blank. So the display will be Blue and Black instead of Black and white.... Suppose I have grounded the signals well.... Now what is still required is sync signals. H-sync and V-sync to be fed to the corresponding pins of VGA cable.
You may think of a sync seperator from the input signal. No . I dont want that . Leave that option. I want to genearate the syncs externally. And I want a good range. 50-100 Hz for Vertical sync and 30-95KHz for H-sync. These signals will be supplied to their respective pins. Then I can see the display on the monitor. I can tune the Syncs to get perfect display.
So what I need is
1)To know whether this will work.(If this wont work, please tell how to teak this. Dont provide a complete alternative solution like RGB to VGA converter. I know that. What I need is a good range for sync tuning)
2)sync generating circuits with option for fine tuning in the specified range and volatage levels according to monitor.
3)I have a monochrome TV circuit set at hand(with option for V-Hold and H-Hold). Please tell how to tweak it to get the sync signals from it.
Thats it....
"There ain't no rules around here. We're trying to accomplish something." -- Thomas Alva Edison
So what I need is
Thats it....
