aspirinnnnn
Member level 1
- Joined
- Jan 4, 2012
- Messages
- 33
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Beijing,China
- Activity points
- 1,511
When I do the after P&R simulation in VCS , I encountered such a problem :
the SDF file generated by the PT seems cannot be back annotated correctly, the SDF file can not properly back annotated with the .v file, the simulation result is wrong ( I observed the wave file ,there is no delay at all), later i repalce the SDF file with encounter generated SDF file ,everything checked fine.
Is there any difference between the two SDF file (Format ? Usage?), if there is any, how do i use them properly in VCS ?
