I'm new to this forum and at first I want to say "Congratulations" to your work. Great community where I often found help in the past. But now, I've got a questions and so I hope you can help me.
I'am doing my first chip and in approx. 1 week it is tape-out deadline and I'm nearly finished. But now I want to recheck my constraints while synthesis and pnr. At this moment I only constraint my IOs with set_input_delay regarding to the master clock. Now I want to use a virtual clock for better IO constraints how described here: **broken link removed**
If I understand this example correct, the virtual clock in the circuit in front of the chip arrives 1 ns later then the master clock and the clock pin of the ASIC. This is exactly what I need. In my case the Circuit in front of the ASIC is an FPGA, so I can shift the clock. Therefore I want to say: "the delay of the clock in the FPGA is at least 1 ns and at most 3 ns". So there is not only one valid case and the FPGA design is easier. But how to tell this in sdc (for design compiler, encounter, prime time)?
I found set_clock_latency -source -min and -max
and set_clock_latency -source -early and -late
So what is the difference between? And what should I use for my case? For example:
set_clock_latency -source -max 3 or set_clock_latency -source -late 3
Thank you very much for your help,
Marc
