SD1289 initialization code
bianchi77
California
Friends,
I've tried to initiate TFT LCD with chipset SD1289,
Photo of the result :
Init code :
    void Lcd_Write_Com( int  DH)	 //ÃüÁî
        LCD_RS=0;
    	LCD_CS =0;
    	LCD_DataPortH=DH>>8;
    	LCD_DataPortL=DH;
    	LCD_WR=0;
    	LCD_WR=1;
    	LCD_CS =1;
    void Lcd_Write_Data(int DH)	//Êý¾Ý
        LCD_RS=1;
    	LCD_CS =0;
    	LCD_DataPortL=DH;
    	LCD_WR=0;
    	LCD_WR=1;
    	LCD_CS =1;
void main_init(void)
   LCD_RS = 1;
  LCD_WR = 1;
  LCD_RD = 1;
  LCD_CS = 1;
  LCD_REST = 0;
	//P1 = 0xFF;
	delayms(100);
	LCD_REST = 1;
	P2 = 0x00;
	delayms(20);
	P3 = 0x00;
	delayms(20);
   // Start screen initialisation
   Lcd_Write_Com(OSC_START);          //Start Oscillation
   Lcd_Write_Data(0x00);
   Lcd_Write_Data(0x01);
   delayms(30);
   Lcd_Write_Com(DRIVER_OUT);            //Driver Output Control
   Lcd_Write_Data(0x23);
   Lcd_Write_Data(0x3F);
	delayms(30);
   Lcd_Write_Com(LCD_DRIVE_AC);       //LCD Drive AC Control
   Lcd_Write_Data(0x06);
   delayms(30);
   Lcd_Write_Com(POWER_CONTROL1);     //Power Control (1)
   Lcd_Write_Data(0xA8);
   Lcd_Write_Data(0xA6);
   delayms(30);
   Lcd_Write_Com(DISPLAY_CONTROL);    //Display Control
   Lcd_Write_Data(0x33);
   delayms(30);
   Lcd_Write_Com(POWER_CONTROL2);     //Power Control (2)
   Lcd_Write_Data(0x05);
   delayms(30);
   Lcd_Write_Com(POWER_CONTROL3);     //Power Control (3)
   Lcd_Write_Data(0x30);
   Lcd_Write_Data(0x0B);
   delayms(30);
   Lcd_Write_Com(POWER_CONTROL4);     //Power Control (4)
   Lcd_Write_Data(0x20);
   delayms(30);
   Lcd_Write_Com(ENTRY_MODE);         //Set Display color mode for 65k color
   Lcd_Write_Data(0x68);
   delayms(30);
      Lcd_Write_Com(SLEEP_MODE);         //Exit Sleep Mode
   delayms(30);                //delay 30ms
   Lcd_Write_Com(POWER_CONTROL5);     //Power Control (5)
   delayms(30);
   Lcd_Write_Com(HORIZONTAL_RAM_START);   //Horizontal RAM address position start/end setup
   Lcd_Write_Data(0xEF);                  //decimal 239
   Lcd_Write_Data(0x00);                  //decimal 0, i.e. horizontal ranges from 0 -> 239
   delayms(30);                                 //POR value is 0xEF00 anyway. This address must be set before RAM write
   Lcd_Write_Com(VERTICAL_RAM_START);     //Vertical RAM address start position setting
   Lcd_Write_Data(0x00);                  //0x0000 = decimal 0
   delayms(30);
   Lcd_Write_Com(VERTICAL_RAM_END);       //Vertical RAM address end position setting
   Lcd_Write_Data(0x01);                  //0x013F = decimal 319
   delayms(30);
   Lcd_Write_Com(RAM_WRITE);              //Commande d'ecriture dans la Memoire ecran
   LCD_CLS(BLANC);                  //send blank  (mode 16 Bits)
Does anyone have experience in initializing this SD1289 LCD ? I'm using AT89LV55 MCU
Thanks
  • SSD1289.pdf
