Scrolling text 2x16 LCD PIC16F887
gabriemrc89
hy i want to scroll some text on my lcd 2x16.
on first line i want my name end on the second line some data collect from senzors( collecting data from senzos is done).
i just need some code lines to scroll that information whit diferent speeds on the two lines if can help me please tell me
---------- Post added at 23:10 ---------- Previous post was at 22:54 ----------
an example YouTube - ‪scrolling text with LCD 2X16 PIC18F452 microchip mcu‬‏
i want the 1st line scroll like second line but diferent speed
What development software are you using? MPLAB, MPASM, Hi-Tech C, CCS, MikoC, etc?
Reactions: vet
    vet
Here's a PIC project using MikroC which scrolls text across LCD remotely controlled via serial port to PC:
A PIC Serial LCD project
You should be able to download the project code and use it as a template for your program.
Reactions: vet
    vet
i start to read now i hope this information resolve my problem. i don't need to use comunication whit pc
If you have a similar PIC as was used in the project, make any modifications you need and run it to see the features.
Running the program as a demo with give you some incite into the code routines you are interested in.
I would also check the MikroC libraries, I thought I saw scrolling text routines last time I looked.
I own MikroC Pro, but rarely use it. I prefer other compilers.
Well that disappointing.
The good news is I checked MikroC's libraries and they support scrolling text:
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char txt1[] = "mikroElektronika";
char txt2[] = "EasyPIC6";
char txt3[] = "Lcd4bit";
char txt4[] = "example";
char i;                              // Loop variable
void Move_Delay() {                  // Function used for text moving
  Delay_ms(500);                     // You can change the moving speed here
void main(){
  ANSEL  = 0;                        // Configure AN pins as digital I/O
  ANSELH = 0;
  C1ON_bit = 0;                      // Disable comparators
  C2ON_bit = 0;
  Lcd_Init();                        // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);               // Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
  Lcd_Out(1,6,txt3);                 // Write text in first row
  Lcd_Out(2,6,txt4);                 // Write text in second row
  Delay_ms(2000);
  Lcd_Out(1,1,txt1);                 // Write text in first row
  Lcd_Out(2,5,txt2);                 // Write text in second row
  Delay_ms(2000);
  // Moving text
  for(i=0; i<4; i++) {               // Move text to the right 4 times
    Lcd_Cmd(_LCD_SHIFT_RIGHT);
    Move_Delay();
  while(1) {                         // Endless loop
    for(i=0; i<8; i++) {             // Move text to the left 7 times
      Lcd_Cmd(_LCD_SHIFT_LEFT);
      Move_Delay();
    for(i=0; i<8; i++) {             // Move text to the right 7 times
      Move_Delay();
The code above is an example of move text left and right. Checkout their LCD library documentation in the IDE.
Let me know if you have any more problems implementing your project.
the code work very fine i use that for start i can't figure out how to scroll the bought lines in the same time but with diferent speeds
I'm a beginner. Can anyone provide a CCS C Compiler code for the same function???:-|
hi, can is use this code?? i use mickro c
Lcd_Custom_Config(&PORTB,0,1,2,3, &PORTC,4,5,6);
LCD_Custom_Cmd(LCD_CURSOR_off);// Turn cursor off
LCD_Custom_Cmd(LCD_CLEAR);
can i use 2 diferent ports(B for data and C for lcd command)???
is much simple to proiect the hardware. i did some tests but the answear "controller received data whilst busy"
