gbugh
Member level 5
- Joined
- Mar 15, 2013
- Messages
- 80
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Fort Worth, Texas
- Activity points
- 2,236
I see a lot of Schottky diodes designed and advertised specifically for TVS and I don't see PIN diodes advertised for TVS yet I see PIN diodes that are cheaper, have lower capacitance, lower ON resistance and just as low or lower leakage current.
The PIN diodes have a higher forward turn-on voltage also, which means I can receive high voltages from the magloop's high Q voltage peaks combined with strong local signals and it won't clip the input signal as quickly as the Schottky diodes would.
It seems like I have to use 2 Schottky diodes in series in each direction to do what just 1 PIN diode in each direction could do.
So can I just as well use PIN diodes to protect a high input impedance JFET input LNA used to sense a voltage maximum across the tuning capacitance of a magloop antenna?
Thanks, George
Thanks, George
