schematic for USB to USB file transfer cable - where?
bimbla
Advanced Member level 1
pl-2301 network
Where is the schematic for USB to USB file transfer cable be obtained?
Does the software for USB networking exist?
Will the performance be better than regular Ethernet type network?
All contributions welcome!
Thanks for your time and efforts.
bimbla.
elcielo
Full Member level 6
Networking
https://www.prolific.com.tw/fr_products.htm
PL-2301 USB-USB Bridge Controller
is a low-cost high-performance single chip solution that provides bi-directional connectivity between any standard USB compliant host systems...
PL-2302 USB-USB Network Bridge Controller
provides a quick and easy solution to construct a network via USB port instead of any Network Interface Card...
PL-2311 USB-Ethernet Bridge Controller
integrates a 802.3u fast Ethernet controller with a USB interface for the host link...
PL-2501 Hi-Speed Host to Host Bridge Controller
is a single chip Hi-Speed USB Host-to-Host Bridge Controller. With PL-2501 embedded cable, users can quickly transfer large amount and large size of files directly from one PC to another.
hurry
Newbie level 2
only can this problem be solved in hardware?
can software do the similar stuff as the chips?
vsop
Member level 2
east
basically, this problem is still solved by the software. this asic should provide a nic driver, and it works similar to that from Ethernet type network. thus it is taken as one nic device from os's point of view. why this asic exists? i only can say where can we find a device w/ 2 usb ports?
