scan compression not same as what is expected
newebu
Newbie level 5
Newbie level 5
I have read a statement on compression ratio that, effective compression will be less than chain:channel ratio . That means if I have generated EDT logic with chain:channel ratio of 10, I might get around 9.5. Please let me know the reason for actual reduction in compression.
What I've studied is compression ratio is defined as (total number of flops in design)/(chain length including edt flops), So this gives the exact compression ratio for the design, if we consider chain:channel ratio, all the chains may not have the exact chain length, So you'll get an approximate value.
