Hi...
Thanks for the reply. Btw, from the schematic, y is there a need to use capacitor?
How do I choose e capacitor value?
Wat u mean by the pot?
My advice is to use fixed resistors, calculate the value and your done, if you have board space put 2 in parallel to have adjustment possibility.
The voltage divider ratio can be calculated. If I am using 10K as R1 and 2.1K instead of potentiometer. Will it b fine as well?
Dear Sir,
You have all the data you need, its a very simple, if not the simplest possible schematic... if you aren't confident build just download some free circuit simulator
