sampling of human voice
thisistausif
Member level 2
india
voice sampling rate
hello
what the correct sample rate for sampling of human voice properly by using ADC
what would be the affect if rate is less than required ?
csa1980
Newbie level 5
voice sample rate
the sampling rate i think must be within 300 - 3khz..
if the rate is going to be small then u will get a voice which is expanded...the duration of each sample will increase
Circuit_seller
Full Member level 5
sample rate for voice
Hi
The minimum reasonable sampling frequency of human speech is 8kHz. By the way after sampling you can use VOCODER to decrease this rate.
naresh850
Full Member level 3
voice sampling frequency
standard is 8000 samoles/secound
coz human voice freq range is 3.3khz.
wowhaha
Banned
sampling rate voice
To avoid any problems of aliasing, best sampling rate will be 10KHz.
mondunno
human voice sampling
hello
the articulation bandwidth of voice is (300Hz to 3Kz), which makes 8KHz minimum sampling rate(this is for making out words clearly, lesser would work but its not optimum)
less sampling rate makes voice more noisy, to hear... (effect is known as aliasing in general)
rakesh_vnit
Member level 3
india
voice sampling
hey....
the minimum samplin rate of any human voice that gives u a clear data will be somethin around 8k samples/sec. but this actually depends on the application.... its obvious that more the data the better u get the info out of it. like when u want to go for some recognisin and reproducin system u need a much higher , 'coz u need a bit more info to get the output reproduced. on the other hand just for a recognition system u can do it wid 8k sample/sec, which would reduce the aliasing....n obviously satisfies the nyquist criteria....
thisistausif
Member level 2
india
minimum sampling rate for voice
hey rakes_vnit
for reproduction at some reciever we need some extra means 10kHz would be enough or more required??
rakesh_vnit
Member level 3
india
phone voice sample rate
hey....
as i told u earlier reproduction needs more information n hence greater sampling rate.
i think u r takin the lpc(linear predictive coeff) or cepstral coeff. to represent the signal when u r trainin the system n later on from these u would reproduce them. i such a case the more samples that u take the more info u have as coeff. which u can reproduce.
i precisely cant say which freq would be good for u ...it depends on the quality u want ... so my advice is start with some higher freq say 15k Hz and go down 10...until u think u r satisfied with lowest freq possible.
regards,
rakesh
