singaperumal
Newbie level 1
we r doing project in biomedical.. we r using adc0808 interface with 8051 to measure the signal from piezo-crystal sensor.. in A to D conversion what is thesampling frequency????
Hello!
May be that will help you at least when you sample sinusoidal and co-sinusoidal signals:
“A New Approach to Sampling Sinusoidal and Cosinusoidal Signals”, P T Petrov,
https://www.ieindia.org/pdf/88/88ET104.pdf
Also may be it will be useful to know:
“Sampling of the Simplest Signals” P T Petrov
https://www.ieindia.org/pdf/89/89CP109.pdf
Any feedback is welcomed
BR
Petre Petrov
Firstly, I would suggest that this side topic be considered for a new thread.ark5230 ,
Thank you for the post.
Hi, permute
Thanks.
Ok, you can put it in a separate threat, but this one is named “Sampling frequency ?” and seems appropriate title for me”.
In all cases singaperumal will be forced to select the sampling frequency nad to test the system.
Although I am still interesting in the topic it seems too complicated for that forum.
The ideas was to tell singaperumal and people like him/her to use 4x or more in order to have better reliability of the samples and better SNR in samples, etc. The amplitude of the samples is vitally important for the system.
Of course singaperumal should read the data sheet of the ADCV and post the schematic diagram
Ok, many people have rediscovered the wheel and etc, so there is nothing bad about that. In almost all cases we do not know who the first discoverer was. Even in our days when everything is recorded the important push or idea for discovering something comes from the outside world, etc.
Defining the simplest signal, how to sample and reconstruct them has vital importance for the measurement in the sampling and reconstruction system.
The clear terminology has vital importance for the advanced in any field.
Usage of samples with enough amplitude plus the equations of the known test signals is the only good way to calculate the parameters of the sampled signals and to evaluate the parameters of the sampling and reconstruction system.
The two definitions of the sampling theorems of C E Shannon are not the same and both definitions are not applicable the sampling and reconstruction systems. Noting can be done to save them. The same is applicable to his information theory.
Fourier is oversimplified, etc.
As a conclusion my position will not change because I do not want to read misleading terms and theories and to mix people like Nyquist and Shannon in the sampling theory. That does not sound good but the reality is like that.
