abhinavpr
Junior Member level 2
i have to sample a 16bit data bus at 50 MHz into a 300 Mhz domain.
as the reading is faster than writing, should i use a FIFO for this? what would be the FIFO depth?
or should i simply sample the data bus every 6 clk cycles in 300 MHz domain and use 16 2-stage synchronizer on each bit of the data bus?
is there any other efficient way of doing it?
-abhinavpr
-abhinavpr
