Sample the recorded sound in matlab...How ? Using MATLAB.
aisar190
Newbie level 1
Newbie level 1
hello,
actually i need to measure the speed of car by its passing sound...i already record the sound and need to process it, so i can apply the doppler shift theory on it...the problem is...how can i sample the sound that i have recorded ealier..i need to sampled the sound first before i do the calculation...i need to do this in MATLAB...because my project is using matlab...
Re: Sample the recorded sound in matlab...How ? Using MATLAB
Hi
I don't remeber the command, but you can create a vector from a wave file, search the help. :)
Reagrds
Mauro Casse
Added after 7 minutes:
Hi
I have googled about and I found an m-function that should work for you, the function name is wavin. Follow the link for more help
http://www.soundslogical.com/suppor...ocumentparts/wavin.html Regards Mauro Casse
Added after 4 minutes:
Sorry..
Built-in function for reading wav file is called "wavread"
Press
help wavread
for learning, how to use it.
aisar190, you didn't say how you recorded it.
If you used an ordinary tape recorder, then you need to digitize it into your computer. If you are using Windows, then try the Windows Sound Recorder accessory, or MATLAB's wavrecord function.
If you recorded it on your computer, then it is already sampled, so you can simply use something like MATLAB's wavread or auread functions as vadkudr suggested.
If you recorded it on a digital camcorder, then there are other ways to import the sound data.
