Do this data cable for C55 is not compatible with C62 Mobile phone?
If you hava the cable like in this link, the probably yes.
2. What is the standard communication protocol for siemens cellphone
3. Do Siemens C62 understand the AT commands, I pressume it does as what i have read in the other post for siemens.
From what i know about the Simens mobile, they all work with AT Command. Try diffrent boud rate 9600 or 115200. Each time write AT[enter] and see if you get OK or even 0 back.
Try this link. its the AT Command for the C35. It will give you a good referance to start with.
Good luck.
