S-parameter conversion
noorm
Newbie level 5
s-parameter conversion
Hi all any has tutorial about Conversion of S-parameters to y-parameters or vise versa
wizardz
Member level 3
s - y parameters conversion
Refer to text books as "Microwave Engineering" by David Pozar.
Also, many softwares have these conversion functions, you even do not need to know about the background theory but be careful about the Characteristic Impedance set up.
for example, ADS, Matlab.
noorm
Newbie level 5
ads s to y parameter
i mean i need matlab code for these conversions
tsubasa
Newbie level 6
s parameter to y parameter conversion
you can write the expressions in the above link in MATLAB.
good luck,
dingjingfeng
Full Member level 4
conversion parametres s en parametres y
if you use the ADS, you can check the Y parameter, and you can get the Y Parameter dircetly.
and I think you can also transfer it easily in other software.
