s parameter and give y parameter
star22
Member level 2
hi freinds
i need m file that receive s parameter and give y parameter (s parameter in polar mode)
please guide me
thanks
rautio
Full Member level 5
North Syracuse, NY
Download SonnetLite (free at www.sonnetsoftware.com, I work for Sonnet). Bring up the data viewer and read in your S-parameters (provided they are in Touchstone format). Then go to the Output menu. Select Y-parameters and magnitude/angle and click on save. You will have your Y-parameter data file.
haitaoz
Member level 3
I used MWO to do that.It is really simple,u just input the S-parameters as data file,then choose the y-parameter in the curve setup for that S-parameter data file.Then done!
flatulent
Advanced Member level 5
Middle Earth
AdLAB Plus ($50 US or so) has a module that converts between all parameter types and common terminal (base, emitter, collector or gate drain source). It will also plot stability circles.
wjnbry
Member level 2
it's a easy work.
i think adlab,,mwoffice,ansoft,ads should do it.
