Running makefile in vsim gui mode.
vineethsukumar
I am working on UVM using Questasim.I have created a makefile. I have two test cases.When I am running it from Questasim it is running in transcript.I have added add wave -r /* command also.But wave window is blank.I am working in windows.
Same happens if I am running in Cygwin also.Gui is not coming up.Everything is running in command line only.I am attaching the makefile below.
How to solve this issue???
###################################################################RTL FILES
RTL = ../DUT/*
#####################################################################FILE_LIST
FILE_LIST = flist
DEFAULT_TEST 	= "my_test2"
###############################################################TOP_MODULE
TOP_MODULE = my_top
###############################################################SIMULATION PARAMETERS
COVERAGE = -coverage
COVERAGE_DATABASE_FOLDER = coverage_database
COVERAGE_FOLDER = coverage
LOG_FOLDER = sim_log
UVM_VERBOSITY 	= "UVM_LOW"
UVM_OPT 	= +UVM_VERBOSITY=${UVM_VERBOSITY}
UVM_AWARE_DEBUG = -classdebug \
		  -msgmode both				\
		  -uvmcontrol=all			\
		  -debugDB=questa.dbg			\
		  -assertdebug			\
		  -onfinish stop			\
		  +uvm_set_config_int=*,recording_detail,400 \
#		  +UVM_CONFIG_DB_TRACE \
		  +UVM_OBJECTION_TRACE
VSIM_OPT 	= -voptargs="+acc" \
				-novopt \
		  -sv_seed random
###############################################################DO_COMMAND
DO_COMMAND = -c -do "log -r /*;radix hex -showbase; echo $Sv_Seed; add wave -r /*; run -all; coverage save ./$(COVERAGE_DATABASE_FOLDER)/$$i.ucdb ; q;"
##################################################################TEST_CASES
TEST_CASES = my_test2 my_test_with_1_1
#TEST_CASES = my_test2 my_test_with_1_1 my_test_with_32_1 my_test_with_alternative_1 my_test_with_max_clk_divider
#TEST_CASES = my_test_with_ass_0
#TEST_CASES = my_test2 my_test_with_1_1 my_test_with_32_1 my_test_with_alternative_1 my_test_with_clk_less_than_20 my_test_with_max_clk_divider
###############################################################CREATE LIBRARY & FOLDERS
vlib:
	vlib work
	mkdir $(COVERAGE_DATABASE_FOLDER)
	mkdir $(LOG_FOLDER)
##############################################################COMPILE FILELIST & FILES
comp: vlib
	vlog 						\
		+acc +FecUdpEffort=3 -sv -mfcu -f $(FILE_LIST)
###########################################################RUN SIMULATION
run: comp
	for i in $(TEST_CASES) ; do \
		vsim $(UVM_AWARE_DEBUG) $(VSIM_OPT) $(COVERAGE) $(DO_COMMAND) $(TOP_MODULE) -l ./$(LOG_FOLDER)/$$i.log +UVM_TESTNAME=$$i $(UVM_OPT); \
	done
	vcover merge -out $(COVERAGE_DATABASE_FOLDER)/my_result.ucdb ./$(COVERAGE_DATABASE_FOLDER)/*.ucdb
	vcover report -html -htmldir $(COVERAGE_FOLDER) $(COVERAGE_DATABASE_FOLDER)/my_result.ucdb
#################################################################CLEAN-UP
clean:
	rm -rf *.log
	rm -rf work
	rm -rf transcript
	rm -rf *.wlf
	rm -rf $(COVERAGE_FOLDER)
	rm -rf $(COVERAGE_DATABASE_FOLDER)
	rm -rf $(LOG_FOLDER)
