mpatel
Member level 4
I used to work with a software called Xilinx Chipscope, which allows to debug preselected signals/variables/ports on FPGA in runtime after hardware implementation. By this software, person can create generate a memory block and place it in during design stage. Connect the inputs of this memory to the required signals to verifiy. Proceed with normal synthesis and implementation procedure.
This allows all kind of hardware realtime debugging for Xilinx FPGA as far as I know. Now the questions are:
1. Is there any other software which can do this ask for Xilinx or even for other FPGA/ASIC?
2. Is there any other procedure for such hardware debugging other than using such softwares?
