run motor via ldr and pic 16f877
lamterteg
Newbie level 3
Newbie level 3
Hi PIC i am new begginer on pic programming
as i want to start a project named running motor via ldr with pic16f877:
when a source light light on ldr a dc motor runs
when the source shutts off the dc motor shutdown
i've already start programming using microc but i get a problem that motor is not running
code:
HTML:
void initialise(){
   TRISC=0xfe;
  TRISA=0x01;
  ADCON0=0b10000001;
  ADCON1=0;
PORTC=0;
 void convert(){
  while(GO_DONE);}
 void light(){
          int lightlv =((ADRESH<<8)+ADRESL);
          if(lightlv>365)
          PORTC=1;
void main() {
    initialise();
    while(1){
    convert() ;
    light();
    delay_ms(4000);}
the simulation:
Check with this code
unsigned int adc_value;
void main()
     TRISA=0xFF;
     ADCON1 = 0x80; // Analog channel select channel2 and channel 3
     TRISC0_bit = 0;                                // set RB0 pin as output
     while(1)
           adc_value = ADC_Read(0);   // Get 10-bit results of AD conversion
            if(adc_value>365)
               RC0_bit= 1;
            else
               RC0_bit= 0;
It is not suitable to connect DC motor directly with micro controller. Better connect with L293d h bridge driver
void main()
     TRISA=0xFF;
     while(1)
            if(adc_value>365)
               RC0_bit= 1;
            else
               RC0_bit= 0;
thanks so much for the code but the motor still not running
i think that i didn't calculate the adc value(365) very well i as you said "Better connect with L293d h bridge driver".
mikroC PRO PIC code attached. I have used PIC16F877A. PWM is used for speed control of motor. What are you trying to do ? Solar Tracking ? If yes, use stepper motor.
  • LDR + Motor Control.rar
