Run Cadence Virtuoso ADE L simulation with multi-core
thinh1165
Newbie level 5
Ha Noi, Viet Nam
Does the ADE L simulation run with multi-core? When the simulation running I just saw 1 core usage 100% and the others around 10% usage. How can I run the simulation with multi-core so that can reduce simulation time?
Thanks!
I use Cadence 6.1.7 spectre circuit simulator, is that what you mean? Library is TSMC180nm
This is the logFile:
HEADER
"PSFversion" "1.00"
"Log Generator" "drlLog rev. 1.0"
"Log Time Stamp" "Wed Jul 25 17:55:55 2018"
"simulator" "spectre"
"version" "15.1.0.284.isr1"
"date" "5:55:55 PM, Wed Jul 25, 2018"
"design" "// Generated for: spectre"
"signalNameType" "spectre"
"simMode" "Spectre"
"measdgt" 0
"ingold" 2
"sst2usecolon" 0
TYPE
"analysisInst" STRUCT(
"analysisType" STRING *
"dataFile" STRING *
"format" STRING *
"parent" STRING *
"sweepVariable" ARRAY ( * ) STRING *
"description" STRING *
VALUE
"tran-tran" "analysisInst" (
"tran"
"tran.tran.tran"
"PSF"
("time")
"Transient Analysis `tran': time = (0 s -> 10 ms)"
) PROP(
"data_type" "swept_scalar"
ok. this is my "spectre.out":
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 15.1.0.284.isr1 64bit -- 12 Nov 2015
Copyright (C) 1989-2015 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: sleepyvirus Host: bkic HostID: 7F0100 PID: 7271
Memory available: 5.0355 GB physical: 8.2372 GB
CPU Type: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
All processors running at 2808.0 MHz
Socket: Processors
0: 0, 1
1: 2, 3
System load averages (1min, 5min, 15min) : 17.5 %, 6.5 %, 3.5 %
This is a virtual machine
Simulating `input.scs' on bkic at 10:46:43 AM, Wed Jul 25, 2018 (process id: 7271).
Current working directory: /media/DATA/simulation/testswcap2/spectre/schematic/netlist
Command line:
/home/cadence/MMSIM151/tools.lnx86/bin/spectre -64 input.scs \
+escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre0_5464_3 -format psfxl -raw ../psf \
+lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 7271
Loading /home/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
Loading /home/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
Loading /home/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
Loading /home/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
Loading /home/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
Reading file: /media/DATA/simulation/testswcap2/spectre/schematic/netlist/input.scs
Reading file: /home/cadence/MMSIM151/tools.lnx86/spectre/etc/configs/spectre.cfg
Reading file: /home/cadence/PDK/TSMC18/models/spectre/rf018.scs
You use Spectre 15.1.0.284.
Can you understand ?
Command line:
Option for multithreading, "+mt" is not specified.
