I’m working with IAR Embedded Workbench IDE running the BLE simple_peripheral example on a cc2650 chip using a XDS110 Debug Probe.
Everything works fine, if I flash the stack with Project>>download>>download active application and then run the app in debug mode with Project>>download and debug. It jumps to main() and when I hit run it works.
I want the application also to run without the debug probe. Shouldn’t the main() run on start up if I use the Project>>download>>download active for the stack and the app?
I have set the -r parameter for the flash loader to retain the flash
Hope anyone of you is familiar with IAR and can help me out
