RTL Logic Gate help - 2x In OR / 3x In XOR
juz_ad
Full Member level 2
Full Member level 2
Hello,
I'm looking to build a 2x input OR Gate and a 3x input XOR Gate using Resistor/(NPN)Transistor Logic.
I have this schem of a 3x Input NOR: https://en.wikipedia.org/wiki/File:RTL_3-Input_NOR_Gate.svg
1) From that schem, if I remove 1x Input and either Invert the output or take the Q Output from the joined Emitters (hmmm - not so sure about that option now...) - does that give me a 2x Input OR?
2) Is a 3x Input NOR the same as an XNOR? i.e. If I invert the output of that schem I get a 3x Input XOR from that XNOR? The truth tables suggest not - but I'm asking anyway.
If not! Anyone got any pointers to a 2x In OR and a 3x In XOR using RTL?
Thanks.
J
First, I think you need to write out your truth tables, that will help you answer some of your questions.
A 3input NOR is most definitely NOT the same as an XNOR (look at your truth tables!)
Yes, if you invert the output of a NOR you'll have an OR. And vice versa.
