Help
Advanced Member level 2
rs485 adapter schematic
I would to use RS485 for my interfacing between PC and few other serial module.
What's the step should i start on the Hardware and Firmware(Protocol) side?
Example I had 3 node (node1=PC, node2=MCU1, node3=MCU2).
My PC only had one serial RS232 port, and the MCU also only had one serial. If i would like to use standard RS232 for all the node in interface, so i just have to put a RS485-RS232 convertor?
As i know the basic RS485 circuitry is show bellow.
Thank You.
Thank You.
