Note: This feature currently requires accessing the site using the built-in Safari browser.
Actually I cant understand your question..
but, i can tell some tips regarding metal routing..
You can route metals over MOS but you should not touch or short the MOS terminals with the SAME mETAL.. fOR EXAMPLE, IF you use metal1 means u cant draw over mos becuase the drain and source of the mos covered with metal1 so u can use metal 2 and others,, no problem to route over MOS..
HOpe u understand this.. and Any doubt ask me..
but i heard that for critical analog and rf circuits the metal over poly should be avoided????
