dw_man
Junior Member level 3
- Joined
- Aug 7, 2013
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 188
I am routing a design in IC Compiler. From what I understand, ZRoute is a newer faster method of routing a design.
If I use this method route_zrt_auto, is it then possible to do optimizations using the route_opt command if I use the -skip_initial_routing switch? I am just slightly confused as to whether they can be used together as there doesn't seem to be any command to optimise ZRoute.
If I just use the regular routing method, and then verify_route, I seem to get much different results than if I use the zrt method followed by verify_zrt_route. Is this normal and what is the reasoning for this?
